Ignition Switch
Old Jan 12, 2014 | 05:03 AM
ObsidianOne's Avatar
Default Ignition Switch
Before I bought my 04 CBR600 F4i, according to the PO, someone tried to steal it with a screwdriver. There was a big chunk of metal floating around in there, but I ended up getting it out. However, it still requires me to find a sweet spot when trying to turn the key so I want to replace the switch. Is part# 35100-MBW-A11 what I'm looking for?
Should I really expect to spend between $100 and $150 for one? Someone told me that almost every bike uses 'shear bolts' that you're supposed to tighten until the end snaps off and I would have to drill/cut them out in order to replace it, is this true?
After I buy it, do I have to have a locksmith rekey the new ignition to my key? Thanks in advance
Old Jan 14, 2014 | 12:59 PM
highwaypatrol's Avatar
I'm not sure how the ignition lock is mounted or how you get it off to replace it with a new one and it may be that the new lock comes with a key or set of keys. Maybe other members have more information. I think everyone's locks are different but I could be wrong. Sorry I can't be of more help!
Old Jan 14, 2014 | 03:21 PM
PossibleOne's Avatar
Welcome Crew Technician
Regarding the re-key, you would have to get a locksmith to reset the tumblers to operate your key. There is different kinds of lock cylinders of course. Some can be set up to program using one tumbler pattern, others can be set up to use two, for example you may want to have two keys, one that will operate say the ignition and your underseat hatch for instance. One would be like a master key, and one would be set to the secondary pattern so it will only turn the ignition and not open the hatch. For example. More commonly seen/used with Valet type keys where you want to give them the key but one that will not open glove box and/trunk.
snoman181
Jun 22, 2012 07:01 PM
Kuroshio
Aug 16, 2009 04:48 PM
kyeman11
Jun 1, 2009 04:51 PM
nutter
May 5, 2009 10:58 AM
seldon929rr
Nov 14, 2006 01:46 PM
