Well now Im confused....setting valves and 2 won't gauge now?
I'm setting the valve clearance on my 06 F4i. I checked them all before taking apart and ordered the new shims I needed. Replaced what was needed, put everything back together and checked clearance again. Everything checks perfectly except the intake valves on #3 cylinder. Specs call for .008". One valve I didn't change the shim, the other one I replaced smaller to give more clearance. Now I can't even get a .002" feeler gauge in there. Why are just these two intake valves giving me such a problem? Engine spins over by hand fine, everything else measures correctly. I'm pretty confused.
Correct, one shim was not changed, one went smaller, no I can't get clearance on either one. I checked to make sure the shims were seated correctly, along with making sure the cams were installed correctly and I torqued down the cam plate in the correct order [I'm using the factory service manual, which is quite vague honestly]. I didn't think about switching the buckets. I guess its possible, but the 1.90" shim stayed in its bucket the entire time so I don't think it's probable. I got everything put back together so perfectly, sucks taking it back apart again lol. I appreciate the ideas guys.
I had the same exact issue when I did mine last month. Measured, calculated, then ordered the needed shims. got everything back together and properly timed only to find out that the clearances were now so tight, I could barely get even my smallest gauge in.
Problem ended up being a miscalculation. Long story short, I used a positive value, as opposed to negative when I calculated the need shims and ended up going up .007(for example) instead of .007 down, making the valves off by .014(again, example).
I seriously doubt thats your issue, but figured I'd throw it out there.
Thought I'd update in case anyone else reads with the same problem. I took everything apart, again. Checked the shims and buckets, verified cams were set to TDC [which is not the mark cast into the case cover, not even close]. My only logical conclusion is I somehow completely messed up on those two valves only. I must have had no clearance and somehow convinced myself I was getting some. No idea how it happened. I put the buckets in without shims and had loads of clearance so this is my only idea. I bought some much smaller shims to try tonight and see if I get anywhere.
Armstrong
06-08-2006 08:31 PM
