gear shift issue
Old Apr 22, 2024 | 04:50 PM
Bill1987600f's Avatar
Sorry the little stud on the left of the spring i seated that in the middle
Old Apr 23, 2024 | 01:01 AM
dannoxyz's Avatar
You need new spring. Both those arms should be straight and parallel about 4mm apart.
Old Apr 23, 2024 | 01:02 AM
Ahh ok ,I’ll order one, and does the stud sit inside the two arms
Old Apr 23, 2024 | 01:05 AM
dannoxyz's Avatar
Yes, stud sits exactly in between two arms of spring. When you shift one way, stud pushes one spring arm away from other. Its increased preload then pushes stud back to centre. When you shift other way, stud pushes other way. Other spring arm then pushes it back to centre position. At rest in that position, stud touches both spring arms.
Old Apr 23, 2024 | 04:20 PM
Old Apr 24, 2024 | 02:36 AM
Good hammering and she came out , this is how spring looks
Old Apr 24, 2024 | 11:06 AM
dannoxyz's Avatar
I found this photo from manual. That pin is supposed to be in between shift-spring arms. I suspect that's why one of the arms is bent on yours.
Bräk
Apr 15, 2023 12:22 PM
Lund
Feb 23, 2014 05:18 PM
90_300zxTT
May 9, 2011 07:58 AM
jdsjunkyard
Dec 11, 2010 05:30 AM
929b0y88
Jun 3, 2007 09:58 PM
