Electrical problems
Old Sep 3, 2006 | 05:03 PM
glempo's Avatar
Default Electrical problems
Ok so to start of for awhile now ive been having a problem where my batterie dies if i let it sit for more than i week, and i mean completely dead. So yesterday i went to ride it and had to charge the battery, and when i got it in the bike i started, but i turned over alot. I think thats because it was cold and i didnt have the choke on, and when it started it ran kinda crappy for a few min, but i think thats cuz i flooded it tryin to get it to start.
So im riding and everything is good, i was riding for about ten or fifteen minutes when i decided to go to stop at my friends house.
The bike runs fine right up until i pull into the driveway, but it dies right as i pull in. so i think maybe i was in to high a gear and let the clutch out and it died(because ive done that a few times goin around corners) But instead the bike wont start back up. the lights come on horn works, but the starter doesnt even come on at all. There is no turning over no nothing.
So my questions are
has anyone ever had a problem like this?
Wheres is the starter on a 96 cbr 600?
and where are good places to look for voltage leaks?
Thanks for any help anyone can give!
Old Sep 3, 2006 | 09:32 PM
mikequinn's Avatar
Default RE: Electrical problems
Sounds like your battery has had it. but if you want to check for leakage this is the test:-
Turn the ign off and disconnect the NEG lead from the batt' terminal get a multimeter and set it to mA (milliamps) connect the negative probe to the battery, & the positive probe to the disconnected lead.. The reading should not exceed 1.2mA. If it does exceed this you have some sort of short circuit in the loom which needs investigating. and can be a real pain in the ***......
If the reading is 0.00mA your fine and nothing to worry about, but i'm sure it's the Battery
Old Sep 4, 2006 | 05:25 AM
glempo's Avatar
I ad been think battery but i just bought it, and the lights all come on, it just doesnt start. So yeah...but ill definatly try that Voltage check.
Old Sep 4, 2006 | 09:40 AM
pacemaker's Avatar
Get your regulator checked, common problem. Same thing happened to me, thought ok battery (8 years old) bought a new one and it and still went flat. I replaced my reg with a heavy duty one. This forum has a lot of people with the same sad tale.
Old Sep 6, 2006 | 05:36 PM
glempo's Avatar
OK, so since i have to do this at my friends house, where can i find the regulator on the bike, and is terribly difficult to get to/remove or is just your average electric plug thing?
dcaldwell
Oct 6, 2009 10:20 PM
thetrick13
Aug 11, 2009 10:13 AM
f3gatorfan3388
Nov 19, 2007 02:28 PM
rblevins4130
Nov 10, 2007 04:36 PM
dizzie56
Jul 9, 2006 01:59 AM
