Chain replacement
Old Feb 9, 2006 | 04:02 AM
nizmo's Avatar
Default Chain replacement
I searchecd and didnt find anythign... how often do you folks suggest changing your chain? Mileage or year whatever.. Thanks
Old Feb 9, 2006 | 04:34 AM
shraz's Avatar
Default RE: Chain replacement
10-15K miles
Old Feb 9, 2006 | 04:38 AM
scotty8583's Avatar
To guage whether or not to change the sprockets you look at the teeth. The teeth will become poiny or "sharp" looking. They can also have a sweeping tidal wave look to them. Both mean you should replace sprockets and chain. 10-15k is a good estimate though.
Old Feb 9, 2006 | 09:44 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Chainstretch is a better indicator. Most shop manuals will have the maximum stretch listed for a given number of links.
Old Feb 9, 2006 | 12:12 PM
caseyd's Avatar
You can also pull the chain at the back of the sprocket. If you can see "a lot" of the tooth, then you need to replace it. It is also good pratice to replace the sprockets (front and rear) as they develope a wear pattern. I know "a lot" is a loose term, but it's all I got
OZZY_F4
Dec 17, 2024 07:04 AM
wattufaka
Nov 24, 2010 08:53 PM
trebbien
Apr 28, 2008 12:19 PM
speedra500
May 11, 2007 06:01 PM
Delmustator
Apr 20, 2005 08:25 PM
