Rear blinker not bright enough
Old Feb 8, 2006 | 12:35 AM
aeroworks's Avatar
Default Rear blinker not bright enough
Ok, heres my problem.. I bought a 929rr and it came with the brake light intergrater kit. so the blinkers work on the brake light. problem is when the turn signal is on you can hardly see it blinking. if a cop is behind me i would surley be pulled over, its that bad. and i am talking about at night..
In daylight the Brake Light isn't bright either.. can't tell if the light comes on. at night the Brake Light is OK but thats about it.
Could it be the bulbs are junk and new/differn't brand would be brighter? or is this common with the integrater kit?
any help would be greatly apreciated. thanks [>:]
Old Feb 8, 2006 | 02:04 AM
Calkidd's Avatar
Default RE: Rear blinker not bright enough
I suggest Clear Alternatives LED lens, but becareful of knock offs. CA has a great product and their LED's are very bright.
Old Feb 8, 2006 | 02:57 AM
aeroworks's Avatar
thats basicly whats on there now, a clear lens with 2 red bulbs in there. you think a bulb change would do it? heres a photo of the back end, sorry its not a btter photo.
Old Feb 8, 2006 | 03:40 AM
cjbettis's Avatar
ORIGINAL: aeroworks
I have the Clear Alternatives light for the rear and it is really bright...uses like 6 times the number of leds than stock...so way brighter...both with red brake and yellow turns (was $86)
That was for the full taillight to swap out. No led kit that you have to do yourself.
If it really is as dim as you should swap it out..not only for cops but safety.
Old Feb 8, 2006 | 06:05 AM
Calkidd's Avatar
We are talking about LED's which will be much brighter than your bulbs. Here is another alternative which is really interesting.....High Tech Speed.
Old Feb 8, 2006 | 10:59 AM
aeroworks's Avatar
sweet, i really le rate as your factory blinker is flashing. Depending on your model of bike, removing your turn lights may cause your turnike those ufo lights. but not looking to spend that much right now [>:]
The FAQ on the UFO lights i found this question that concerns me.
"Q: Can I remove my blinkers if I get this kit?
A: You should check the legality in your state of running without the factory blinkers, it may or may not be permissable to remove your stock blinker lights. Our kit will flash at the sam signals to flash more quickly. If you are unsure if your blinkers will operate incorrectly after removal, try unplugging them before you install the kit - they will operate the same way after you install our kit. You can install resistors to slow down your blinkers if they operate too quickly - give us a call and we'll make sure you can find what you need."
So does that mean i might have to add resisters to the setup so the light doesn't blink a million times a second? if so, then the videos of the differn't light effects and speed settings for the blinkers are bull****. am i missing something here?
here is something i found on ebay.. do you think this might work? anyone try these before?
http://cgi.ebay.com/ebaymotors/2-LED...36170276QQrdZ1
Old Feb 9, 2006 | 02:58 AM
aeroworks's Avatar
ok, i just bought the HIGH TECH SPEED UFO light ( http://www.hightechspeed.com/product...29/index.shtml ). They look really sweet, and fullt programmable. Also bought the proton turn signals for the front, ALSO badass! can't wait to put these bad boys on.
Old Feb 9, 2006 | 08:42 AM
doncollins's Avatar
Retired Administrator
Where did you buy from...
Old Feb 9, 2006 | 09:43 AM
Calkidd's Avatar
ORIGINAL: doncollins
Old Feb 9, 2006 | 12:15 PM
aeroworks's Avatar
well, the hightech speed website wasn't working when i tried to checkout. so i found http://www.spyderracing.com/ that had the ufo light cheaper. so i bought the proton marker lights, ufo light, a pair of icon pursuit gloves, and a power commander 3
DuramaxLLY
May 4, 2013 11:26 PM
dc1
F2 Tech
Jul 15, 2011 10:48 PM
johnnyx
Jul 10, 2009 04:35 PM
fujimoh
Apr 19, 2008 04:25 PM
jk_on_cbr
Jun 16, 2006 11:45 PM
