left rear blinker out...not bulb
Old Jun 16, 2006 | 09:21 AM
jk_on_cbr's Avatar
Default left rear blinker out...not bulb
my left rear blinker has stop working all of a sudden but I check the bulb and its fine. Does anyone know what the problem could be?
Old Jun 16, 2006 | 09:39 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: left rear blinker out...not bulb
Loose wire ... turn the blinker on and check with a voltmeter. Keep checking (go from bulb back towards fuse) until you get power. Hopefully it's just the connector is loose or has crud on it.
Old Jun 16, 2006 | 10:01 AM
wayne_carey's Avatar
is your front indicator jammed on / flashiing at all?????? this would indicate power is getting to the flasher can. Check you have power at the light using a ground you know is good, eg the negaive terminal on the battery. Once you have established power here. Check the ground at the light. hope this helps
Old Jun 16, 2006 | 10:59 AM
jk_on_cbr's Avatar
I will have to take a look at it this weekend. The front blinker is working fine there might be a loose connection but I just want to make sure that it is not the flasher if the left front/rear and right front are all working fine.
Old Jun 16, 2006 | 03:48 PM
MT Wallet's Avatar
fuse maybe?
Old Jun 16, 2006 | 11:45 PM
jk_on_cbr's Avatar
it was a broken wire on the back of the bulb holder.
DuramaxLLY
May 4, 2013 11:26 PM
estate4life
Mar 16, 2012 12:09 PM
BIGT94z
Aug 22, 2011 12:13 PM
