left turn signals not working but dash blinker blinks?
Old 08-10-2011, 02:37 PM
Default left turn signals not working but dash blinker blinks?
i have a 02' f4i that is having a interesting issue. bad ground some where maybe? anyway the front and rear turn signals do not work at all but the dash blinks like normal. the previous owner put in led front/rear that are 2 wire so i have no running lights (which ill fix) just curious if anyone has ran into this issue as well and can point me in the right direction to look? thanks!
-travis
Old 08-22-2011, 01:46 AM
update:
found the left side front was wired wrong and then the rear bulb was corroded. before i went to ride fri night both sides blinked and so did the dash. after 10 miles into the ride the left side would blink when it felt like it and when it did not the dash would just light up the arrow not blink. the right side does not work at all now. when u hit the right signal switch it dims the headlight light for 1 sec. dash doesnt blink. any idea's? im a wiring newb
Old 08-22-2011, 12:13 PM
It could be a number of things but hopeful its just bad wiring and/or loose or corroded connections. Use this: Convert 2 wire signals to 3 wire to clean up the front turn signal wiring and restore the running lights. I used this and it worked great.
Just in case, this is the wiring diagram for the rear turn signals.
Hope this helps
scoots
09-01-2018 04:24 PM
CBRf4iX
04-22-2013 09:54 PM
MrBlaze
08-31-2009 12:01 AM
MrBlaze
08-17-2009 02:07 AM
mongoose2494
09-03-2005 01:58 AM
Quick Reply: left turn signals not working but dash blinker blinks?
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
