Electrical blinker Led Vs. Conventional bulb
Old Mar 15, 2012 | 12:13 AM
estate4life's Avatar
February 2012 ROTM
Question Electrical blinker Led Vs. Conventional bulb
Ok member, I've just went with led blinkers, taken out my old conventional bulb, now the blinker blinks a lot faster? I heard that you must add a resistor? Does anyone familiar with this? How many ohm of resisitor?
Old Mar 15, 2012 | 12:33 AM
vice's Avatar
yes you will need a resistor I believe it needs to be 6 ohms? could be wrong.
honestly the faster blinking seems to be more attention getting than a slow blink. so I would consider just running a fast blinking turn signal
Old Mar 15, 2012 | 02:12 AM
adidas_007's Avatar
Yeah the faster blinking is because the leds use less wattage and the relay thinks there is a bulb out. You can ether add wattage resistors or replace the relay that is led ready.
I personally changed out my relay.
http://www.superbrightleds.com/cgi-b...rake-turn.html
Old Mar 15, 2012 | 02:44 AM
CJardine's Avatar
Track junkie & modaholic
Go with the new relay. You seem more like the kinda guy who wants to do it right.
Old Mar 15, 2012 | 07:34 AM
Turbulenz's Avatar
Official Welcome Crew
Amen..$12 plug and play
Old Mar 15, 2012 | 07:45 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
I installed a SuperbrightLED relay in mine. For $9 it was fairly easy. Scroll down the page to the motorcycle applications. I have the LF1-S-FLAT. It fit my OEM connector perfectly.
Old Mar 15, 2012 | 10:07 AM
February 2012 ROTM
Thanks for all feed back...problem is my front blinkers is still using the old bulb. My taillight, I replace with LED + intergrated signal....believe the relay is for both front an back? Does this mean I need to go with led blinkers too for the front?
Old Mar 15, 2012 | 10:18 AM
Turbulenz's Avatar
no... I have LED flushmounts (HotBodies) in front and stock signals in the back.. no issues.
Old Mar 15, 2012 | 11:35 AM
RoadiJeff's Avatar
With the SuperbrightLED relay you can have a combination of both regular bulbs and LED. I have LEDs for the rear signals and regular bulbs on the front and they all blink just fine.
Old Mar 15, 2012 | 11:51 AM
February 2012 ROTM
Nice...it's for my 94' cbr900 ....I'll go with the relay ...
