left rear blinker out...not bulb
Loose wire ... turn the blinker on and check with a voltmeter. Keep checking (go from bulb back towards fuse) until you get power. Hopefully it's just the connector is loose or has crud on it.
is your front indicator jammed on / flashiing at all?????? this would indicate power is getting to the flasher can. Check you have power at the light using a ground you know is good, eg the negaive terminal on the battery. Once you have established power here. Check the ground at the light. hope this helps
I will have to take a look at it this weekend. The front blinker is working fine there might be a loose connection but I just want to make sure that it is not the flasher if the left front/rear and right front are all working fine.
BIGT94z
Aug 22, 2011 12:13 PM
