Chain replacement
To guage whether or not to change the sprockets you look at the teeth. The teeth will become poiny or "sharp" looking. They can also have a sweeping tidal wave look to them. Both mean you should replace sprockets and chain. 10-15k is a good estimate though.
You can also pull the chain at the back of the sprocket. If you can see "a lot" of the tooth, then you need to replace it. It is also good pratice to replace the sprockets (front and rear) as they develope a wear pattern. I know "a lot" is a loose term, but it's all I got
