900rr brake light
Old Aug 28, 2019 | 07:05 AM
mikegm045's Avatar
Default 900rr brake light
The brake light on my 1996 Fireblade remains on after using the foot brake. Any ideas? Hope its a quick fix!
Old Aug 28, 2019 | 09:24 AM
74demon's Avatar
The rear pull switch is probably sticking, Give the shaft a good cleaning and see if the issue is resolved.
Old Aug 29, 2019 | 06:45 AM
mikegm045's Avatar
Thanks for this. Probably misunderstanding something, but I'm not sure about the 'pull' switch reference - rear brake lever operates on a 'push' switch doesn't it?
Old Aug 29, 2019 | 12:36 PM
74demon's Avatar
Honestly, I'm not sure. Mine works from a pull switch via a spring connected to the lever.
Old Aug 30, 2019 | 02:21 AM
wes 17's Avatar
A simple mechanism, just inspect, clean and adjust. Releasing tension on the spring slightly should show you the lamp going out and more travel required to get it to illuminate.
Best of luck
Old Aug 30, 2019 | 05:12 PM
mikegm045's Avatar
Got it - was looking at it incorrectly. Thanks again. Mike
Old Aug 30, 2019 | 05:14 PM
mikegm045's Avatar
Thanks for this - appreciated
BubbaCbr600f2
Jul 2, 2019 06:04 PM
testflyer
Mar 24, 2014 07:53 PM
Jeffcbr600f2
F2 Tech
Jun 28, 2012 04:11 AM
vtchopperdude
Sep 9, 2010 02:55 AM
d_tran
May 9, 2009 08:43 AM
