brake light question
Old Sep 2, 2010 | 09:34 AM
vtchopperdude's Avatar
Default brake light question
hey fellas, alright I just picked up my first CBR several months ago, and I love it! But I have noticed that when I pull the front brake lever, the brake light lights up, but not as bright as when I apply the rear brake; is it supposed to be like that? I also noticed that if I apply just a little bit of front brake, the light is dim, then the brightness increases the more I apply front brakes; is that a CBR thing or is something not right?
Old Sep 2, 2010 | 02:59 PM
justasquid's Avatar
somethings not right. Sounds like perhaps a bad switch at your handlebar brake lever.
Old Sep 2, 2010 | 04:19 PM
well, if the switch was bad, it wouldn't work at all right? is that pressure switch something that slowly stops working, or just goes out all a sudden?
Old Sep 2, 2010 | 06:46 PM
justasquid's Avatar
I've never heard of this problem before, so Im only guessing. But, the switch is either on or off. If the switch is sticking internally, it could be not letting the full amount of voltage across the swtich so you get a dimmer light. If you've ever had a bad ground, you know that bad grounded lights are always dimmer. Can you see the switch to see if the plunger is coming out quickly? Maybe remove the lever and push it by hand to see if the switch feels sticky.
Maybe the futher the plunger moves outward, the connection inside the switch is made better, therefore letting more voltage across?
Old Sep 2, 2010 | 09:23 PM
yea, I dont know either, its kinda funky; I have the same feeling as you, its an "on" or "off" switch, not inbetween; the only thing I can think of other than what you have mentioned is that its a variable pressure switch...the more pressure, the brighter the light.....
Old Sep 5, 2010 | 02:30 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Well, since the MSF teaches us to always use both brakes it shouldn't really matter.
Old Sep 9, 2010 | 02:55 AM
hoppa2k6's Avatar
I'd grab a new pressure switch from Brad at SuperBike Supply and while your at it, a new set of brake lines (may as well if you are installing a banjo bolt pressure switch!)....that is, assuming you don't already have aftermarket lines...in which case, you already have an aftermarket pressure switch that could be bad..... Never seen it happen, but I suppose all mechanical things are bound to fail...
gunslinger1274
Nov 9, 2011 07:07 PM
eljrc16
Jun 27, 2009 01:12 PM
ACSHoops33
Jan 21, 2009 07:22 PM
camaropower
Dec 3, 2008 09:13 PM
goosane
Sep 29, 2008 10:22 PM
