Brake light question
Old Jan 20, 2009 | 06:51 PM
ACSHoops33's Avatar
Default Brake light question
Just got an 07 600 RR on friday... My brake light worked then, and I was told today it wasn't working while riding. Upon inspection... they were right. It doesn't work for the front or rear brake. I'm perfectly capable of doing anything to this bike, however, before going through everything I was wondering if anyone had suggestions of where to check first or if this was a common problem?
Old Jan 20, 2009 | 07:15 PM
WhiteDealershipRice's Avatar
Default RE: Brake light question
Are you getting the running light only, or no light at all?
No light at all = blown fuse
Running light but no brake light Might be bad switches, or bad conection on the brake light.
The OEM brakelight has 3 wires: BlackGround
Black/white-Running light
Black/yellow-Brake light.
check the connections
Old Jan 20, 2009 | 07:16 PM
D2VW14_20's Avatar
Can still be a fuze with running but no brake, atleast on the 06;s
Old Jan 20, 2009 | 07:24 PM
ACSHoops33's Avatar
I have a running light, but no brake. I'll check the fuse tomorrow. Check the connection to the stupid ugly brake light assembly?
See, I'm putting in the CBR Heaven taillight as soon as it comes, so i figured I'd ask first.
Old Jan 21, 2009 | 06:22 PM
snakerb's Avatar
I know this doesn't help you with your problem, but I have a question. What is a CBR heaven taillight and do you have a link?
Old Jan 21, 2009 | 07:22 PM
redbbwoy's Avatar
chk the "tightness" in the brake line...for instance wen i removed my rear brake/foot peg and re-installed, i had the problem where the "BRAKE" light wus on constantly. There shud b a lil circular plate in which you can adjust it..that iiz if your fuses r perfectly fine??
gunslinger1274
Nov 9, 2011 07:07 PM
vtchopperdude
Sep 9, 2010 02:55 AM
eljrc16
Jun 27, 2009 01:12 PM
camaropower
Dec 3, 2008 09:13 PM
goosane
Sep 29, 2008 10:22 PM
