600 F3 Suddenly completely dead!
Old Oct 8, 2019 | 12:37 PM
Antti Suonio's Avatar
Default 600 F3 Suddenly completely dead!
The bike has been running pretty well for its age and has never shown signs of electrical issues until today.
I turned the key, all the appropriate lights and headlight turned on but when I hit the ignition the bike died completely.
I checked all the fuses as well as the main fuse (and replaced them for good measure) but I still don't get any signs of life. Nada. Zilch. Zip.
I also tried to jump it but I still didn't even get lights when I turned the key. I checked the rectifier but all the connections look good and the battery leads are also connected well.
Any ideas where I should look? Thanks!
Old Oct 8, 2019 | 02:43 PM
wes 17's Avatar
Reads like your ignition isn’t operational. Try playing with the key whilst it’s in the “on” position to see if you get any lights up. You might have to bridge the ignition circuit to prove this.
Old Oct 8, 2019 | 03:08 PM
I tried playing with the keys and turning them around but to no avail. Guess I'll try bridging the ignition circuit tomorrow. What is the best way to go about doing that? Should I bridge the switch or what do you reccomend. I'll keep you posted, thanks for your help.
Old Oct 8, 2019 | 03:55 PM
Check your kickstand switch. Also insure the bike is in neutral.
Old Oct 8, 2019 | 04:59 PM
Kickstand switch seems fine and the bike is in neutral
74demon's Avatar
Check the actual voltage at the battery before looking any further.
Old Oct 9, 2019 | 08:18 AM
Probem solved! The battery was fried. Voltage was good with the bike turned off but showed 0 when I turned it on. Thanks for everyones help. Crazy how a battery can just pop like that and not show any other signs
Old Oct 9, 2019 | 08:27 AM
wes 17's Avatar
Happy days. Glad your sorted mate.
rider0033
May 30, 2016 06:01 PM
NE1000F
Jul 20, 2010 10:51 PM
Kuroshio
Aug 16, 2009 04:48 PM
mtcrss2006
Nov 6, 2008 09:21 PM
all_squirled_out
Nov 5, 2007 01:20 PM
