2005 cbr 600rr fuel pump not priming
Old May 2, 2018 | 05:52 PM
CBR600RR561's Avatar
Default 2005 cbr 600rr fuel pump not priming
HEY THERE. I'm having a issue is I'm not getting a fuel pump prime sound when ignition switch on the ON position. I check my wires going in to the pump and the brown with blk wire has 12v but on the other side of the connector that goes to the pump it drops down to 4.35 volt. Ive seen a lot of threads stating about a pink wire off the ignition switch that a diode goes bad but my cbr is a 05 which means it only has 2 wires coming out of ignition. I also checked both wires coming out from my ignition switch and both wires have 12volts. Ive already by pass the bas and the kick stand and still get no fuel pump priming sound as well as I put str8 power to the pump to assure that it is working and it does make the usual priming sound.
any help would be appreciated.. THANK YOU ALL
Cmarchandpr
Jun 19, 2013 05:04 PM
decannon04
May 22, 2012 07:49 PM
tmanana
Jul 12, 2009 10:45 PM
Adrjunkie
Jun 22, 2009 07:38 PM
03bladeRunneR
Mar 21, 2006 01:47 AM
