F4i Spark Plug Installation Problem
I’m trying to change out my spark plugs and I ran into a problem with trying to put the new one in. When I took out the old plugs they came out fine, but now when I’m putting the new ones in it seems they won’t catch the threads and go back in. I’ve tried all the plugs and every hole but they still won’t twist back in. Could it be that I’m doing something wrong or idk.
are you using the spark plug tool to do it or something else?
Are the new plugs freely spinning inside? In my case when I lower them down using the honda provided tool, they always seem to go right into the hole and thread in properly. Either you are not lowering them correctly or your threads are gone. Try some more if still the same, then perhaps you can pop the valve cover out and then check if you are lowering them correctly into the desired place?
pipedcbr
Dec 29, 2010 12:25 PM
