Spark Plug Wire Problem
Old Sep 10, 2013 | 07:45 PM
dsenk48's Avatar
Default Spark Plug Wire Problem
Hi guys, I just changed my spark plugs and noticed that #4 wire is not seating onto the plug. The other 3 wires kind of pop on and off of the plugs but #4 just wont catch. Any suggestions? Will this cause the plug to not spark at all, and does that mean that I am missing a cylinder. Can i test it or just squeeze the contact point inside the wire to form a better bond? the old plug was dark so I can tell that it was working for at least a little bit but I do not know if it is working at the current moment and I don't want to break anything.
Thanks!
Old Sep 10, 2013 | 08:27 PM
Sebastionbear1's Avatar
Try and work out why it's not seating on the plug. Is it broken (the metal clip - or just been 'stretched'. If it just looks like it has opened up a bit, gently try to squeeze it closed with some long nosed pliers.
Cheers, SB
Old Sep 11, 2013 | 08:15 AM
dsenk48's Avatar
yea the inside looks like the others. I do not think it is broken. Almost looks like some one replaced it and just put the wrong size wire back on so now it wont catch. I will try to squeeze it a tiny bit and see if it helps
Old Sep 11, 2013 | 03:51 PM
Here's one from left field.
When you changed the plugs did they all have the little screw on nipple on top? Some brands they are removable - others not. It didn't fall off before the plug was put in?
The spark plug lead needs it there to hold onto the plug.
Cheers SB
Old Sep 11, 2013 | 08:19 PM
dsenk48's Avatar
nah the plug is fine. It was like that on the old plug as well. I will probably be firing the bike up tomorrow night or friday so I will try to see if it feels/sounds weird but I am not very sure what to look out for. It is also getting inspected this weekend so if no one thinks of anything then I will ask the mechanic.
JLAvila
Apr 23, 2022 10:09 PM
KoukiFC3S
Jun 25, 2021 04:52 AM
flat-line
Sep 17, 2012 01:16 PM
seatea123
Jul 26, 2011 08:28 AM
hypeshipe
Mar 24, 2009 09:18 PM
