02 600f4i won't start after replacing stator cover
Old Sep 17, 2005 | 03:08 AM
deeksmooth's Avatar
Default 02 600f4i won't start after replacing stator cover
couple facts.. i dumped the bike and my stator cover got scratched a bit. bought a brand new OE cover. i've never done this before, i just go in and see how it comes apart and put it back together.
when i took the cover bolts out and broke it loose from the gasket, some oil started to pour out.. so i tightened 4 points back down and drailed all the oil out of the engine into a pan. then i put the drain plug back on and took the 4 bolts off the stator cover. a little more oil came out, i'm guessing all in all about 1/4th of a quart came out of that area.
anyways, i got the cover off, swapped the alternator coil over in the same position and reassembled w/ some liquid gasket/seal. put the oil back in the engine and then like a tard, i put all the fairings back on w/out doing a test start. well now, i go to start, and the relay clicks, doesn't try to turn over.... battery is dead. so against my owner manual's discretion, i get some cables from my car to my bike (as i have done before) and try to jump start it. won't start, it does try to turn over, but only 1 - 1.5 times every time i hit the ignition button. do i need to put some oil in there somehow?
was supposed to go on a ride with some coworkers tonight but now i can't cause my bike won't start.. hopefully someone can come up w/ a solution asap. thanks in advance.
deeksmooth
Aug 11, 2020 03:22 PM
cbrrrrrrrr
Apr 26, 2010 09:04 PM
Jun 17, 2007 05:52 PM
bluestanger66
Apr 27, 2007 07:48 PM
Bobinbaghdad
Apr 7, 2007 02:12 AM
