What is this noise?
Old Sep 17, 2007 | 04:26 AM
kukku's Avatar
Default What is this noise?
Hi to all,
I’ getting a sort of a rattling / vibrating noise from about 2500 revs upwards. It is loudest when cruising in gear, with a closed throttle (e.g. down a slopey road). At first I thought the chain is either touching the guard or the centre stand, but since it only does from 2500 revs upwards I ruled it out. Can it be CCT? It is still heard after 4000 revs but very faintly probably because probably the Scorpion exhaust drowns the noise.
Old Sep 17, 2007 | 08:09 AM
birdstrike's Avatar
Default RE: What is this noise?
Not to be a hater but this is a forum. We can't hear your noise! Take it to a mechanic and have him listen to it!
Old Sep 17, 2007 | 08:23 AM
kukku's Avatar
Cheers, though maybe someone could relate to my email through exeprience, especially since CCT is very common.
Old Sep 17, 2007 | 09:03 AM
Streetdemon's Avatar
I ♥ CBRF
Sounds like you got yourself a dirty chain.Or possiblythechain tensionis tootight or even the rear wheel is out of alignment. If you’re hearing the noise from the left side then that may be the culprit. CCT is on the right side of the bike. But it is hard to determine the cause without hearing it.
Old Sep 18, 2007 | 03:24 AM
kukku's Avatar
Default Update - What is this noise?
Took it to shop, they said it CCT.However, I'm not 100% convinced as I canstill hear it a little bit if it gets revved in neutral (though much fainter). Somewhere in here I read that CCT is load dependable which I understand it means in gear.Has anyone experienced it in neutral?
Thanks a million for your help.
Old Sep 18, 2007 | 07:14 AM
slip_'s Avatar
Default RE: Update - What is this noise?
Hmm, when I rev mine, I hear it go off at 5,000 in neutral.
Old Sep 18, 2007 | 11:54 PM
atvrider07's Avatar
the faint noise u still hear could be ur valves not adjusted correctly by just a hair. takes some time sometimes to get them exactly right.
Old Sep 19, 2007 | 03:07 AM
kukku's Avatar
Cheers guys, guess will try to live with the CCT and have the valves checked soon.
blind_skater26
Jun 7, 2010 11:43 AM
02HONDAF4IGUY
May 18, 2007 12:40 AM
rangerbrown
May 18, 2006 12:43 AM
maniacmechanic
Dec 30, 2005 11:30 AM
maniacmechanic
Dec 20, 2005 09:31 PM
