tire question
Old May 16, 2007 | 01:15 AM
roldaphat9's Avatar
Default tire question
I just had a bridgestone battlax BT014 190/50 tire put on the rear, the tire has about 2-300 miles on it and i went to power the front end up and all the rear wheel does is just spin... is this tire to soft/hard? um just need to break it in more? whats the deal?wont come up with clutch or powering it up.
Old May 16, 2007 | 06:57 AM
Ruftags's Avatar
Default RE: tire question
don't trust it in twisties if it's spinnin doin lifty. I don't know much a bout tires.
Old May 16, 2007 | 12:46 PM
roldaphat9's Avatar
hmm never thought about that... good point.
Old May 16, 2007 | 03:44 PM
themadpaki's Avatar
you might have an aged tire as well.....
Old May 16, 2007 | 03:46 PM
gixxereater's Avatar
Break it in a bit more. Unless the road is wet or VERY cold a BT-14 should stick no problem. What pressure are you running in it? Also...the profile is screwed up because you SHOULD have a 180 on the rear. You are pulling the tire in more and changing the profile......you might not have as much rubber on the road as you think.........put a 180 back on it.
Old May 16, 2007 | 04:49 PM
Tahoe SC's Avatar
air pressure must be at 50 PSI!
014s stick well...
definitely should stop riding in the dirt.
04F4I0321
Dec 27, 2013 09:24 AM
Jim T
Apr 29, 2012 06:45 PM
Fairlane
Jun 16, 2009 09:17 AM
Phil314
Jun 6, 2009 07:53 PM
tweak mt
Apr 18, 2006 05:49 AM
