Speedometer problems
Old Jan 11, 2008 | 04:45 PM
flashpoint's Avatar
Default Speedometer problems
Hey guys its been a while since i posted on here, but i have a problem that needs fixing. the other day i was on my way to work and my speedo quit working. i have done some searches and found that it is usually faulty wiring or a bad speed sensor. i am going to tear the bike down tomorrow to check the wiring. question is, is the speedo comes on when the bike gets to around 174 degrees and works from then on, but when the bike is cold the speedo will not work. if it is the speed sensor that is faulty (i suspect it is with 34000 miles on the bike) where can i get a new speed sensor? i have searched ebay but have come up empty handed. i also searched bike bandit and found nothing. any feed back is appriciated. Thanks.
Old Jan 11, 2008 | 04:54 PM
jaynd's Avatar
Default RE: Speedometer problems
how many miles are onyour bike? i had 18k on mine when i had the same problem and it turned out to be my speedo sensor.
Old Jan 11, 2008 | 05:02 PM
jaynd's Avatar
sorry, just saw the mileage. through searching on here when mine went bad....i found that when the bike gets into the high teens they tend to go bad.
Old Jan 11, 2008 | 05:48 PM
flashpoint's Avatar
where did you get your replacement speed sensor? i cant find them and the stealership here wants to charge me 150$ for a new one.....
Old Jan 11, 2008 | 05:54 PM
jaynd's Avatar
not sure where to get one at. i had mine replaced at a buddies shop. he charged me $180 to do the sensor and install my rear tire hugger. so idk how much JUST the sensor would be.
i'd DEFINATELY say that is your problem. mine had the same things going on. it would seem as if the speedo wouldnt work until the bike "heated up".
Old Jan 11, 2008 | 06:46 PM
flashpoint's Avatar
there is a few on ebay for an F4. will that work on a 2001 F4i?
Old Jan 11, 2008 | 07:50 PM
letsride's Avatar
If you like I do have a used speed sensor that I can sell you.
Old Jan 13, 2008 | 03:05 AM
p01ishedF4i's Avatar
I am also having the same issues. In addition, after cruising at about 60 mph or so the FI light will come on as well, and will not shut off until the bike is restarted. Anyhow, I've found a good place to purchase the speedo sensor..
http://houseofmotorcycles.bikebandit...4-2001/o/m2050
Click the "Crankcase" option in the scrolling window. Then scroll down on the page and selection 9 will be the speedo sensor for $75. I have yet to purchase it. I will be doing this monday, tearing the bike down, and putting this small sensor in. Bummer.
Hope that helps!
Old Jan 13, 2008 | 08:54 AM
flashpoint's Avatar
well i tore apart my bike yesterday and found that there was some corrosion on the connector to the gauge from the speed sensor. i cleaned the connector with a wire brush and some wd40 and then applied some connection grease. put it back togeather and the speedometer worked. well see for how long though....
Jonesc962
Oct 28, 2013 11:48 AM
highercal
Mar 8, 2011 12:01 PM
highercal
Mar 5, 2011 12:44 PM
waynecbr600rr
Oct 23, 2008 05:11 AM
Jnymack123
Apr 2, 2008 06:00 PM
