RPM's Dropping to zero randomly, High Rpm's & Low Rpm's
Old Jun 23, 2010 | 07:47 PM
Slydell19's Avatar
Default RPM's Dropping to zero randomly, High Rpm's & Low Rpm's
Just recently my 01 600 f4i has been acting up.. around twenty minutes into a ride i will be cruising in 5th or 6th and all of a sudden the Rpms drop to zero, so i get on the clutch and rev it back once or twice and it will gennerally get going again. it has shut off once while going down the freeway. also sometimes coming to a slow turn or stop the rpms just drop and she shuts off. Im in much need of some help because i absolutely love riding..... Im thinking possibly electrical like the kill switch is making contact, possibly a battery issue but i havnt had time to start probing yet. Please send me in the right direction..
Old Jun 23, 2010 | 07:58 PM
Krux's Avatar
Does it start to stutter when it die's?
How is it running otherwise?
Tune up on it recently?
Old Jun 23, 2010 | 08:02 PM
Slydell19's Avatar
When riding down the road it just seems to drop off instantly and shut off but the speedometer stays running and so do the lights.
It has been running just fine otherwise.
and i just changed the oil and radiator fluid two days ago but the problem started about four days ago.
Old Jun 23, 2010 | 08:36 PM
Krux's Avatar
When the bike is just sitting there. Try wiggling the shut off switch and seeing if it turns off. Maybe there is a loose connection.
I would check to see if the Fuel pressure regulator has any wet dampness inside the vacuum hose that connects to it.
Check out if any electrical or anything is hanging. No FI lights I am guessing too huh?
Old Jun 23, 2010 | 08:52 PM
Slydell19's Avatar
No Neither one of the lights has ever come on while riding..
Is it possible that i could have a cloged fuel filter.??
Old Jun 23, 2010 | 09:22 PM
canadian_f4i's Avatar
Have you checked your battery connections? I know my bike was doing this a little while ago. Everytime I hit a big bump the bike would die for a second and then start right back up. Ended up just being a loose battery connection. Good luck.
Old Jun 23, 2010 | 09:36 PM
Slydell19's Avatar
(Canadian_f4i) Acctually i havnt had time to start checking everything out, but i will deff. check that first becasue it all started happening during a long ride that took us over like 200 foot of absolutely horrible road.. thanks for the suggestion
Old Jun 24, 2010 | 03:52 PM
Slydell19's Avatar
So i just checked all my connections and everything seems to be in order,, anyone have any other suggestions?????
Old Jun 24, 2010 | 09:26 PM
jam0837's Avatar
this happened to me last friday night. it did it like 4 times while going 70+. i rode sat sun and mon with no problems tho. idk what it couldve been. any help would be good.
Old Jun 25, 2010 | 03:39 PM
cnicosiaF4i's Avatar
I had the same issue, but the FI light came on everytime it happened. It turned out to be a bad connection with the battery terminals. Try cleaning the terminals, that fixed my problem.
Jesse Tripp
Sep 25, 2013 08:20 AM
geminiscorpion
Jan 28, 2013 08:02 PM
f3streetfighter
Mar 18, 2012 02:43 PM
SchiraF4I
May 23, 2007 04:30 PM
crucialfate
May 7, 2006 03:39 PM
