oil leaking from the shift shaft
02 F4i, got oil leaking from the shift shaft, i ordered the oil seal...has anybody replaced this? how difficult/easy was it? any tips would be great as i have not done this before.
Never heard of one going bad before....hopefully you can install it without removing the shaft, like a pinion seal on a car.
Hopefully its time for a oil change too.
Maybe you could pry the old one out with a fine tipped screwdriver then tap the new one one with a deep socket.
YES!!!...thanks JAM0837, just what i wanted to hear...its a $4.00 part....and i know the dealership will charge at least 1/2 hr for it...save me some money diy
I know this thread is ancient but a friend of mine is having the same problem and i was just curious, do you have to take the cover off to replace the seal?
mxnoah418
Apr 12, 2012 10:15 PM
jnicola
F2 Tech
Jun 10, 2010 01:35 PM
