oil leaking from the shift shaft
02 F4i, got oil leaking from the shift shaft, i ordered the oil seal...has anybody replaced this? how difficult/easy was it? any tips would be great as i have not done this before.
r u sure its oil leaking, and not just chain lube/road debris slopping around?
yes, i am sure.....not alot..but enough to notice.
Never heard of one going bad before....hopefully you can install it without removing the shaft, like a pinion seal on a car.
Hopefully its time for a oil change too. Maybe you could pry the old one out with a fine tipped screwdriver then tap the new one one with a deep socket. |
Originally Posted by Sick97SS
(Post 956231)
i changed mine bc it was leaking. it was really easy. i took a small flat head screw driver a got the old one out. wiped the shaft with a rag and put in the new seal...really easy
Originally Posted by jam0837
(Post 956287)
good to know...thanks!
(Post 956287)
