oil filter
Old Jul 19, 2008 | 03:24 PM
thegame's Avatar
Default oil filter
how the he!l do i get it off?my1st time changing it. cant get my hands in there to turn it
Old Jul 19, 2008 | 04:00 PM
StuDog44's Avatar
Default RE: oil filter
I took both my fairings off. It's a little extra work but it makes getting in there easier. You're also probably going to need an oil filter wrench. I ordered one from ams oil when I ordered my oil. I think it was ten bucks.
Old Jul 19, 2008 | 05:15 PM
Aken's Avatar
July 2008 ROTM
Oil filter wrench, definitely. Or hammer a screwdriver into it if your wrench breaks li-ke mine did last time.
Old Jul 19, 2008 | 08:42 PM
Goose Rider's Avatar
Get an oil filter wrench...the kind that goes on a socket wrench and a 6" extension...bam..problem solved...no need to take fairings off...you can cover up the headers with some foil and shape it into a little funnel so the oil goes right into the pan
Goose
Old Jul 19, 2008 | 09:06 PM
Hayden06F4i's Avatar
or channel lock pliers.....easy and done....or next time get K&N filters, they have a nut welded on to the end of the filter....1 socket, job done.
Old Jul 19, 2008 | 10:06 PM
WOT's Avatar
WOT
Take off your farings and get an oil filter wrench, a strap wrench should do. Sometimes you can turn it by hand. Buy a K&N next time so you can put a socket on it.
Old Jul 19, 2008 | 10:09 PM
FFCBRf4i's Avatar
I just changed my oil today. I used the oil filter wrench.
Old Jul 20, 2008 | 09:59 AM
TBFGhost's Avatar
http://images.google.com/imgres?imgu...3Doff%26sa%3DN
You can get this at sears..... it's the best.
Old Jul 21, 2008 | 11:03 AM
MidnightG35X's Avatar
You should be able to get it off by hand. Oil filters should only be turned 2/3 - 1 turn after the gasket on the filter starts touching the metal.
Turbulenz
Feb 19, 2010 05:09 PM
c_keeton600f4
Dec 28, 2009 02:43 PM
G3NESYS
Mar 12, 2008 12:25 PM
sc929
Feb 25, 2008 08:15 AM
usndocjaysin
Sep 21, 2007 10:18 AM
