noise
Old Dec 29, 2008 | 12:18 AM
wvcbrf4i's Avatar
Default noise
my bike has a little clicking or tapping sounds when bike is running i think it might be the valves i run high test gas is there any thing i can do
Old Dec 29, 2008 | 12:39 AM
bwayers's Avatar
Default RE: noise
check your oil level
if it's low you may not be getting any oil on top of the motor causing the valves to click when the cam lobe depresses the bucket
also, is this right on start up or does it make the noise after it's ran for a while?
Old Dec 29, 2008 | 12:45 AM
wvcbrf4i's Avatar
Default RE: noise
It makes the sound no matter what you are doing driving it idle any thing ok i am a new sport bike rider when you check the oil do you do it when the kick stand down or when they nike is up right
Old Dec 29, 2008 | 01:00 AM
bwayers's Avatar
Default RE: noise
you can do it with it resting on the kick stand
just look to make sure the oil is between the marks on the inspection window
Old Dec 29, 2008 | 02:42 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Default RE: noise
Dude, you have to work on your spelling/grammar/punctuation. Try typing it on Microsoft Word (or similar), then copy & paste it. But anyways...
When you check the oil level in your bike, it has to be while the bike ispositioned vertically straight up& level; not leaning over on the kickstand. Otherwise you willget an inaccurate reading and possibly end up adding too much oil. Also, how many miles does it have? Has it ever had the valves checked/adjusted?
Old Dec 29, 2008 | 08:04 AM
wvcbrf4i's Avatar
Default RE: noise
The bike has 12000 milesand no the valves have never been check for as long as i have owned but i have only had it for 2 weeks
Old Dec 29, 2008 | 11:07 AM
Incognito's Avatar
Default RE: noise
Well, the manual says 16K for the valves. If it were me, I'd go ahead and change the oil & filter; fill it up to the appropriate level, which you should do anywaysinitially after purchasinga used vehicle. Start simple, then progress to the more complicated stuff if that don't work. I'm wondering if the noise you're hearing is not the cam chain tensioner, but I believe that only occurs within certain rpm ranges. Maybe someone else can shed some light.
blind_skater26
Jun 7, 2010 11:43 AM
02HONDAF4IGUY
May 18, 2007 12:40 AM
rangerbrown
May 18, 2006 12:43 AM
maniacmechanic
Dec 30, 2005 11:30 AM
maniacmechanic
Dec 20, 2005 09:31 PM
