Manual Fan Switch Write Up
Old Jun 8, 2011 | 09:03 AM
SN952NV's Avatar
Default Manual Fan Switch Write Up
I've searched to no avail a write up with pics on the manual fan swith install... anyone come across one? I have a solid idea based on other write up's but love pics for back up
Old Jun 8, 2011 | 11:27 AM
Sick97SS's Avatar
You'll probably catch some crap for doing it, because there really is no point for a manual fan switch unless your stunting in parking lots for hours.
Anyways. There probably are not any pics because it's so easy.
Run wire from the positive battery terminal to the positive wire on the fan. Put a switch in the middle, and put a fuse near the battery. Leave the existing positive connection on the fan hooked up. done.
Old Jun 8, 2011 | 01:11 PM
SN952NV's Avatar
I could care less what people think.. It's something I think would be beneficial to help offset the 100+ deg. days here in the Carolinas. There is so much stop and go riding in the city I think it would really help.
Old Jun 8, 2011 | 11:43 PM
itsme71190's Avatar
agreed. im in va. sitting on 225 degree bike at stoplights while its 100degrees out blows....
Old Jun 9, 2011 | 09:57 AM
cynicalrider's Avatar
Check out stuntride.com and search for it. I'm sure you will find some good pics as well as the installation of an additional fan possibly too.
Old Jun 10, 2011 | 08:59 AM
Sick97SS's Avatar
I have to add to my 1st post, while that method will work, there is an easier way.
Found here on stuntlife.com
Even easier just to splice into the thermostat wire on the rad and connect it to a ground. Then run your switch. This way no one can turn your fan on without the ignition ON.
Old Jun 11, 2011 | 11:18 AM
SN952NV's Avatar
Awesome! Thanks for the direction.. I'm going to knock this out today.
Old Jun 13, 2011 | 02:43 AM
Zero1080's Avatar
I'm reusing my gauge from my crash, and the only thing that doesn't show are the numbers for the temp gauge (still lights up). What's wrong with the numbers? And will my fan still work automatically?
Old Jun 13, 2011 | 11:41 AM
is the gauge still pulling information from everywhere else? An educated guess would lead me to believe the temp sensor is ****ed or the wiring from the temp sensor to the gauges.
removebeforeflight
Oct 13, 2014 10:16 AM
swaggard
May 29, 2012 11:45 AM
ffingers
Apr 4, 2008 10:00 AM
Reimche
May 17, 2007 09:57 PM
