Key/ignition issue
Old Sep 12, 2011 | 08:13 AM
lilpaco's Avatar
Registered Users
Default Key/ignition issue
So, I went to hop on my bike yesterday and went to put my key in, and noticed it was completely bent on put sides almost if someone had took a flathead screwdriver and wedged it side to side. So needless to say my key wont even go into the hole right one bit. So after a few choice words I started reading but couldnt find anything really like my problem. So what do i need to order ignition and gas tank replacements? Difficulty of installment? Thanks a ton for any feed back!
mo
Old Sep 12, 2011 | 09:49 AM
causeman8's Avatar
damn thieves sorry to hear that. but yes you are right unfortunately you will most likely need to buy replacements if your ignition is messed up beyond repair(by the sounds of it it is). best bet is to check out ebay or at least thats what id do. you dont have to buy a set you should be able to find just the ignition by itself and use your old key for you gas tank or you can do it the right way and buy the complete igniton/gas tank set. as far as installment goes it should be a pretty easy installment. just unplug your old ignition and plug the new one in. only a couple screws hold it in place and as far as the gas tank just undo the allen screws on the top of the tank and swap the two out. hope this helps.
Old Sep 14, 2011 | 10:02 PM
lilpaco's Avatar
Registered Users
HONDA CBR600 F4 F4I CBR929 CBR 954 IGNITION LOCK NEW | eBay
found this, looking like the only thing I could find. not much else around.
Old Sep 17, 2011 | 11:08 AM
causeman8's Avatar
CBR 600 F4i Ignition switch set 01-06 key gas cap fuel seat lock | eBay
$129 for everything...not too bad. Oh and btw dont go with one of those cheap knockoffs. Tried it in the past and it was garbage.
jacksla3
Mar 13, 2014 05:02 AM
streetfighterF4
Nov 12, 2012 03:34 PM
Sagery
Mar 16, 2011 02:56 PM
NE1000F
Jul 20, 2010 10:51 PM
89cane
Apr 14, 2009 03:17 PM
