ignition issue
Old Apr 9, 2009 | 08:46 PM
89cane's Avatar
Default ignition issue
so i am redoing the f1 new paint and my engine had a gear problem so i did a motor swap just to another f1 motor and i hooked the ignition all up today and turned the motor over to moke sure that was good. then i sprayed some carb cleaner into the intake no carbs or anything then turned the engine over and one of the boots caught fire. so i checked the plug wires and they were all right any ideas?
sorry about being long winded
Old Apr 10, 2009 | 08:07 AM
cbreric's Avatar
that stuff is flamable, are your plugs in and was the kill switch on? if the plugs were in and the kill switch was not in the off position it might have sparked and flashed the carb cleaner.
Old Apr 11, 2009 | 05:29 PM
89cane's Avatar
the plugs are in the wires on tight the kill switch in the on position. i just had the engine rebuilt and am wondering if maybe somthing was left out or it was timed wrong when they did that causing a backfire. the engine turns fine
Old Apr 12, 2009 | 11:58 PM
tripicana's Avatar
i think that is a normal reaction of trying to run a motor without carbs.
when i was little, i started my go-cart with out the carb. dumping gas straight into the motor, the whole thing caught on fire.
Old Apr 14, 2009 | 10:23 AM
89cane's Avatar
cool i will put on the air box and try to run it and see what happens
thanks
Old Apr 14, 2009 | 03:17 PM
cbreric's Avatar
you can hook up just the carbs and see if it will run. if it doesnt than it saves taking the airbox back off again. and you will need the box off to sync the carbs up
jacksla3
Mar 13, 2014 05:02 AM
streetfighterF4
Nov 12, 2012 03:34 PM
lilpaco
Sep 17, 2011 11:08 AM
Sagery
Mar 16, 2011 02:56 PM
NE1000F
Jul 20, 2010 10:51 PM
