Installing throttle cables onto throttle body? Help!
Old 09-28-2010, 03:08 AM
zellster's Avatar
Default Installing throttle cables onto throttle body? Help!
Hey guys, I had taken off the throttle bodies to do some work on my bike. Now that I'm putting everything back together, I'm running into a small problem.
For the life of me I cannot get the bottom throttle cable in it's spot on the throttle drum. I've tried bending the cable with pliers, I've tried turning the drum fully open, I've tried all I can think of. It's in such an awkward place, and I'm running out of ideas. Has anyone done this before? Any advice is greatly appreciated!
Old 09-28-2010, 08:30 AM
skameigh's Avatar
what I had to do was remove the throttle body again... Like the rubber clamps/ Slightly lift the throttle body and install the bottom cable first. Then top last. Once both on, then remount the throttle body. Worked for me as I could not for the life of me get them on without lifting the throttle bodies
Old 09-29-2010, 12:50 AM
Zero1080's Avatar
I feel your pain. You'll have to take stuff off most likely, unless you have lots of patience. But skameigh has a good idea.
Zero1080's Avatar
Zero1080's Avatar
Old 09-29-2010, 02:42 AM
nickp123's Avatar
+1
Lisandro
05-29-2013 11:45 AM
graysonwittwer
03-12-2012 09:53 PM
NobleSandy
08-25-2010 07:06 AM
NobleSandy
05-25-2010 06:59 PM
brianheyse123
12-04-2007 02:56 AM
Quick Reply: Installing throttle cables onto throttle body? Help!
