HT Ignition Coils Check
Old Jun 28, 2017 | 02:33 PM
Nick Richardson's Avatar
Default HT Ignition Coils Check
Hi All
The probes on my multimeter are knackered. I suspect that one if these is faulty. Could I check by unplugging one at a time whilst running the engine to listen for the faulty one?
Nick
Old Jun 28, 2017 | 03:47 PM
74demon's Avatar
Yes. When you find one that's not working, move it to a different cylinder and see if it's still faulty there or if the misfire stays with the original cylinder.
Old Jun 28, 2017 | 03:55 PM
Thanks for that Demon. I was about to do it and then I thought I might damage something. First job after work tomorrow me thinks.
Old Oct 4, 2021 | 07:18 AM
BBlade's Avatar
Hi I got a 2000 929 here do get the right resistance from the pick up but no spark on any of my coils what els can i look at to find the problem . fuel pump do prime .
Old Oct 4, 2021 | 04:00 PM
Do you have 12v on the Black/White wire going to each of the ignition coils? With the Ignition Switch in the On position and the Engine Stop switch in the Run position, you should have a constant 12v.
Old Mar 11, 2022 | 03:10 AM
Brandoscott513's Avatar
What would cause 12v on one side of coil plugs and at most maybe 3 to 4v on the other side? That's with ignition on and kill switch to run and while I'm not turning the bike over. When I crank it the low number side goes up to around 5 or 6v?..... I don't understand I've tried And tested everything except changed ECU...
john87
Jun 6, 2020 11:56 AM
Nick Richardson
Jun 30, 2017 12:58 PM
kemper
May 7, 2015 07:22 PM
michael myers
Jul 19, 2012 07:34 PM
lococbrf2
Oct 11, 2007 04:12 PM
