hid installation question
Old Feb 28, 2014 | 10:56 AM
jeremymik84's Avatar
Default hid installation question
ive tried to research around and havent found much, where did you guys mount your ballasts and is there any precaution needed to waterproof them (maybe a dumb question)
Old Feb 28, 2014 | 01:53 PM
"A"'s Avatar
"A"
AFAIK, most HID ballast come nearly waterproof from factory these days and they are pretty compact in size, not difficult to find place to mount them.
Old Feb 28, 2014 | 10:32 PM
theadamie's Avatar
If it's possible install it all with the front cowling ON !!! Someone else did this online and I regret not doing more research and using this method. I've never been able to get my front cowl on perfectly after installing mine with the cowl off and I have NO IDEA what is catching. The cowl goes on but I have to force it about half an inch and put the bolts in while muscling it into position. If you install everything with the cowl on you're guaranteed that you won't block anything. I asked a friend who owns several bikes and customizes them and he said he always leaves the cowls on during the installs. Probably harder to do it but the result will be better.
Here's the install guide by the genius who left his cowl on.
https://home.comcast.net/~nstama/hidinstall.html
Old Feb 28, 2014 | 10:36 PM
theadamie's Avatar
The stock "bulb-holder-clips-things" won't hold the bulbs perfectly still even if you bend them "which I did" so I used hot glue to make lock them into position. I don't know if anyone else did this but it worked well for me. Hopefully it will be okay in the summer.
Old Mar 3, 2014 | 09:25 PM
sweet, thanks for the replies. i reall appreciate it guys, when i get a spare second ill slap em in and post some pics
Old Mar 4, 2014 | 10:23 AM
Neonfire's Avatar
I have an 02 F4i and took out my windscreen and mounted the ballast underneath my instrument cluster, tucked up out of the way, no mess, all the wires run behind the air duct covers and once the windscreen is back in... you cant see a thing.
Old Mar 4, 2014 | 10:29 AM
theadamie's Avatar
You have the same bike, the same year and the same color as me. We know what's good
Old Mar 4, 2014 | 10:32 AM
theadamie's Avatar
Smart man, I Wish I had talked to you before I installed mine. I have wires hanging everywhere I worry that some ******* might tamper with them someday.
TheShooter
Oct 1, 2012 05:25 PM
fireWire
Mar 9, 2010 05:05 PM
Diablo Runner
Nov 1, 2008 02:39 PM
CBR BoyRacer
Mar 8, 2007 03:50 PM
CBR BoyRacer
May 15, 2006 04:52 PM
