Exhaust installation question
Old Sep 30, 2012 | 12:04 AM
TheShooter's Avatar
Default Exhaust installation question
I just purchased a danmoto slip on and have a question about the installation. When I removed the factory exhaust from the header, there is some kind of heat shield around the header that makes the header a different diameter than the slip on. I don't know if I should remove this shield or just expand the new exhaust pipe. I assume the wrap was there to keep heat from the cat from transferring to the header or vice versa.
Any advice would be appreciated. I am running a 2006 F4i.
Thanks.
Old Oct 1, 2012 | 05:25 PM
jeffjones's Avatar
If it the same as the 01 it is a gasket.
It just ensures a good seal at the mid-pipe, You can try to remove it from your stock exhaust or pick one up at the local stealership for a couple bucks.
fenixv8
Jun 5, 2006 08:27 AM
cbrrookie
Mar 23, 2006 10:34 PM
cbrrookie
Mar 21, 2006 11:04 PM
Rajj
Mar 17, 2006 12:20 AM
mray7
Feb 21, 2006 12:47 AM
