front turn signal replacement
Old Apr 16, 2007 | 05:37 PM
ackerjack's Avatar
Default front turn signal replacement
do you have to remove the entire upper cowl to replace a busted front turn signal??
Old Apr 16, 2007 | 07:53 PM
Jaybird180's Avatar
Default RE: front turn signal replacement
Depends on how it's mounted and aftermarket or OEM.
Just remove it, you'll thank me later.
Old Apr 16, 2007 | 11:40 PM
Daemian's Avatar
ORIGINAL: Jaybird180
+1
Old Apr 17, 2007 | 09:24 PM
ackerjack's Avatar
ok so i went ahead and tried to get it done today but when i removed the cowl i discovered that the replacement signals didnt have the same amound of harnesses coming out of it. I hooked what was there up and it turns out that now the signals do light up however they do not signal when im turning and the dash signals are always on. any idead? all i could think of was trying to unplug it and try the other one since there were two coming from the bike. Sorry if i was a little unclear.
Old Apr 18, 2007 | 04:05 AM
bls5782's Avatar
If I recall correctly when I did mine there are 2 factory connectors. One is for the turn signal circuit, and the other is for the running lights. Just grab a test light and probe to find the turn signal one and use it. leave the other plug there.
Old Apr 18, 2007 | 11:13 AM
LouE37's Avatar
[align=left]The CBR wiring uses a 3 wire setup that utilizes a running light. You will only need to use the signal wire and the ground wire. The running light wire will not be used. Green wireis on both sides and then one side hasorange and the other has blue. Whatever is left over is the running light wire that isnt used. At least thats how mine worked on my 02 F4i when installing my Gregg's flushmounts.[/align]
Old Apr 18, 2007 | 12:14 PM
Daemian's Avatar
when i installed my flushmounts i cut the wires off the old signals (after the connector plug) and used the 2 live wires (i believe 1 is green for run lights and the other is ?? for the signal) and connected them to the 1 live wire from the new signal. Then i connected each ground together.
Old Apr 18, 2007 | 06:00 PM
ackerjack's Avatar
ya i figured i just had them mixed up. the weird part is that these are honda turn signals im putting in, im just replacing the old ones. doesnt make sense why they wouldnt have the same wiring config.
Old Apr 18, 2007 | 09:49 PM
dreadf4i600's Avatar
Maybe they sent rear signals instead of front ones
gpfan1
Jun 13, 2015 07:44 PM
slobo7x
Aug 11, 2009 12:18 PM
rogfog
Mar 4, 2007 05:13 PM
malbojah
Mar 12, 2006 06:12 AM
