Turn signal relay replacement - advice please!
I am just fitting Proton Flushmount front indicators to my Bike after already having fitted rear LEDs a while ago.
Now I am back to fast flashing again which i would rather not have. I have fitted resistors to the rear LEDs but this seems to make no difference to flash rate once the front LEDs are added.
Because there is not much room between fairing and bike and because the ceramic resistors do get hot I am a little loathe to fit them to the front as they will sit up against the inside of the middle fairing cowl and I am bothered about damage. The rear ones are mounted under the seat cowl well away from bodywork but there doesn't seem a "safe" place to fit the front resistors.
So I am looking to change the flasher unit relay and it couldn't be in a much more awkward place to get to right between the front lights.
Can anybody who has swapped out the relay give me any short cuts to changing it out or do I have to go through the whole upper cowl removal, front light removal etc. to do it as per the manual?
Also if I ever sell the bike and re-fit the stock indicators will I also have to change the relay back to the original or does the new relay work with both? Apologies for my electrical ignorance !!!!!
thanks for your help again.
Roger
Roger
RE: Turn signal relay replacement - advice please!
ORIGINAL: rogfog
ORIGINAL: rogfog
Roger
Roger
muckdawg24
09-17-2007 12:13 PM
