2006 turn signal full replacement
Old Aug 10, 2009 | 03:26 PM
slobo7x's Avatar
Default 2006 turn signal full replacement
So I've researched the topic on hotbodies flush mounts and rear undertail eliminators that remove the stock turn signals and relocate the lock. >
http://fatbikez.com/hotbodies-racing...unpainted.html
I got that, but for 06 obviously.
I fully understand how to wire these components, but my worry is the operation of the turn signals once it's all hooked up.
I will be installing hotbodies front flush mounts and rear underbody tail with two led's on side, today.. Just want to know if i need to buy the resistors for each turn signals, so they will flash at the same rate as stock? I've looked through 5 pages here and it's confusing whether I need resistors, diodes, or new LED flasher..
Thanks everyone, my first post here I think!
Old Aug 10, 2009 | 03:33 PM
letsride's Avatar
Just get a new led flasher cost is about $15.00 and is a direct plug in.Saves you lots of time compared to splicing in resistors and does the same thing.
Old Aug 10, 2009 | 03:55 PM
Aken's Avatar
July 2008 ROTM
Bingo.
Old Aug 10, 2009 | 05:19 PM
slobo7x's Avatar
I guess I'll ebay it. Anyone store that might carry this localy?
Old Aug 10, 2009 | 08:20 PM
letsride's Avatar
My local Cyclegear has them.Is there one close to you?
Old Aug 10, 2009 | 09:32 PM
Jerzdan's Avatar
I just put hotbodies flushmounts on my 06 and i also intergrated the stock tail light. I didnt want my front flushmounts to blink super fast so i bought one of these bad boys and it was easy to put on and worked great. http://www.customled.com/products/fl...sher_relay.htm. The hardest part was gettin the front cowl back on. The flasher is right in between the headlights.
Old Aug 11, 2009 | 08:26 AM
xjoewhitex's Avatar
Where is this direct plug in model? Ive looked around to only find universal which id have to cut and splice.
Old Aug 11, 2009 | 10:09 AM
RojerLockless's Avatar
Personally i've never understood why people want to slow down the blinking turn signals. I LOVE how fast they blink when you swap them front and back to LED's not only are LED's brighter but the constant and faster flashing makes me more visible to drivers who dont pay attention to what's going on. The faster and more flashes the more chance Miss. Mini van looks up from drinking her coffee and doesn't plow through me.
That's just my 2 cents.
Old Aug 11, 2009 | 12:18 PM
xjoewhitex's Avatar
Ive kinda wanted the led flasher because well its stock flashing rate, but then again hyper flashers are badass and are SOOOO JDM.
MrBlaze
Aug 17, 2009 02:07 AM
Cun0144
Sep 23, 2008 10:04 AM
ackerjack
Apr 18, 2007 09:49 PM
rogfog
Mar 4, 2007 05:13 PM
malbojah
Mar 12, 2006 06:12 AM
