F4i running rich
Old Mar 30, 2012 | 01:25 PM
  #21
snow_htr's Avatar
I replaced my FPR - the PO had installed it with the little rubber plug still in the hole for the line? Weird. Anyway - same problem.
I'll see if there are any new codes this year and repost.
Got my FPR from Heartland Honda - bought some grips too so it only cost me 50 bucks. (they have a 75$ minimum order I think..)
Have to fix the tank vent - so far running it with the cap open or it pressurizes/vacuums.
Old Mar 31, 2012 | 09:54 AM
  #22
dveldtf4i's Avatar
That little plug was most likely the problem. Glad you got it squared away.
Old Apr 26, 2012 | 04:14 AM
  #23
InlandEmpireRider's Avatar
Can you elaborate on this? Where was the rubber plug?
Old Apr 26, 2012 | 12:30 PM
  #24
Sick97SS's Avatar
They are shipped with a small plastic plug in the FPR orfice to prevent dust/dirt from getting in there. Must be removed before install.
Not to be confused with the rubber o-ring that it needed for the install.
Old Jun 25, 2012 | 10:00 AM
  #25
snow_htr's Avatar
Default RESOLVED my running issue
After having this issue where the bike would run extremely rich and then cut out I found that all the tines in the temp sensor were bent at the SAME angle so that the connector wasn't making complete contact. It would seem to be alright but it wasn't. It looked PERFECT. After about 50 attempts to check it I finally had somebody else look at it - my instincts were right but I just couldn't see the fault. Simple mistake but I don't feel bad because i really went over this thing.
So maybe the temp sensor should be replaced every so often just for giggles. A little extra resistance was all it took to make the bike FAIL.
That's my contribution. Thanks for reading folks!
Old Jun 26, 2012 | 12:23 AM
  #26
mnguyen84's Avatar
the fuel mileage seems fine. the smell of un-burnt gas is normal. older bikes like the f4i are less efficient than more modern sport bikes. however, this is based off my 02 f4i that's overdue for a valve adjustment.
Old Aug 7, 2012 | 11:31 PM
  #27
snow_htr's Avatar
Default Fuel economy..
I've been putting about 1.5 gallons a week through this thing... and I usually go through at least 1/2 tank on my truck doing the same drive. I think that's about 200 miles a week. Maybe 150 depending on how awful the fuel gage in the truck is.
This will probably go down now that i fixed the fuel map in the PCII.
Question about noise - never owned a CBR before so what's the engine supposed to sound like mechanically? I've a whine which I assume is the APE chain tensioner. Anything else I should (or shouldn't) be hearing?
Old Apr 18, 2019 | 07:23 PM
  #28
madkow15's Avatar
Default Need some help please!!!
I have a 04 Honda cbr600f4i, just put a power comander on with map, has kn high airflow filter on and is running super ritch.....just changed oil and the old oil smells like gas.....can anyone help.....and have a small cheap short gp moto exhaust with out any back pressure.....I'm thinking change exhaust. ....map is tuned to a two brothers exhaust
Old Apr 19, 2019 | 12:36 AM
  #29
CaBaRet's Avatar
Dont want to start an air filter war , but have you tried the stock filter back in first?
Cbr`noob
Jul 21, 2017 03:53 AM
mr wilkins
Sep 1, 2010 02:51 AM
Killa071
Apr 15, 2010 12:06 PM
sparks32
Aug 11, 2006 10:06 PM
plastikmelter
Jun 18, 2006 03:13 PM
