F4i Battery dies after long ride
Old Nov 15, 2011 | 10:17 AM
justing66's Avatar
Default F4i Battery dies after long ride
Hey All,
Never had this problem until last week.
I commute once a week from Long beach to San Diego for work. So I make the drive down, make a quick stop (5min), go back to my bike and the battery is dead. So I have someone jump it for me, ride a short distance and turn off the bike .Turn it back on and it starts fine. Another short ride, again..off, on starts just fine. I make the drive back to Long beach, pull into my driveway, turn off the motor to go open the garage door, come back to start it and its dead again.
I was hoping maybe it just needed a good charge, but I haven't made a long trip since to see if it does it again.
Anyone else had a problem like this? Or possibly know a diagnosis?
Thanks
Old Nov 15, 2011 | 10:27 AM
jeffjones's Avatar
Run the charging system tests in the service manual and that might give you a better idea on what the problem is exactly.
I had something along those lines and it was my R/R.
Old Nov 15, 2011 | 10:37 AM
74demon's Avatar
as stated, check your battery and charging system. charge the battery an have it load tested. put a voltmeter across the battery and see if it is charging (13.5v to 14.5v) at 4000 to 5000 rpms. regulator/rectifiers and burned connectors are very common as well as bad batteries. if it is not charging, be sure to check your stator for a open circuit or short to ground.
TechGirl1414
Sep 19, 2011 05:48 PM
SlickNic26
Sep 22, 2010 05:08 PM
Josh198600
Feb 3, 2008 10:14 PM
datjuanguy
Nov 14, 2007 11:12 PM
CoMac
Mar 26, 2005 12:04 AM
