When your battery dies...?
Old Sep 18, 2011 | 08:53 PM
TechGirl1414's Avatar
Default When your battery dies...?
Two friends of mine who we were riding with yesterday (both CBR owners) wanted me to ask you guys a question. What do you do when you are away from home and your battery dies? Do you get it towed? Or do you jump it? IF you jump it, what do you use? Alligator clip jumper cables or something else? Any and all answers will be appreciated. Thanks!
Old Sep 18, 2011 | 09:05 PM
kilgoretrout's Avatar
Administrator - Retired
Jumper cables just like you would a car. Just make sure you don't have the car running.
Another option is bump starting it. 2nd gear is best.
Old Sep 18, 2011 | 09:10 PM
Sprock's Avatar
+1 ....Administrator Kilgoretrout nailed it !
Old Sep 19, 2011 | 05:08 AM
highwaypatrol's Avatar
Administrator answered you question, but why did the battery die? Sounds like it wasn't being charged or something drained the life out of it, because normally riding the bike would keep the battery topped up. Did your friend(s) change the battery now for a new one? If so, check the charging system to see if it is up to scratch.
Old Sep 19, 2011 | 06:12 AM
My battery didn't die, this is a hypothetical question, because my friends at working on getting a patent in something . What if the battery is not easily accessible?
Old Sep 19, 2011 | 06:13 AM
Are* and on* my mobile site won't let me edit.
Old Sep 19, 2011 | 06:35 AM
jeffjones's Avatar
2 feet and a heartbeat for me.
A hill helps also
Old Sep 19, 2011 | 12:46 PM
estate4life's Avatar
February 2012 ROTM
I've personally never jump a motorcycle (dead battery) with a car using jump cable. I don't know if there maybe something not right about it? Of course it will work but it's not guaranteed if it won't mess up you electrical....car idling voltage maybe a very strong surge for a motorcycle. I would not go thru the hassle of removing the cbr seat, call a friend with jump cable. Too much work, I guess. Just hop on CBR, put key into ignition, turn it on, hold the clutch lever, put into 1st or 2nd
gear, give it a push down a
driveway slope, or a friend give up a push on flat pavement, at about walking speed, let the clutch go. Don't give gas or else you may flood the sparks...give gas when fire up...Should start right up!!!!
Old Sep 19, 2011 | 05:31 PM
MadHattr059's Avatar
I've heard jumping off a running car is dangerous. (Electically speaking, of course.
We all know it's dangerous jumping from a moving vehical! lol).
If you get one of the cigeratte lighter jumper setups, you could attach a battery-
tender connector on one side. That would make it easy to carry/use. You do have a battery tender, right? Then all you would have to do for a jump...plug into the car's
cigarette/auxilery power outlet on one end and the other to the battery dongle.
Light weight, compact, easy to carry during the cold season. ;-)
Ern
Old Sep 19, 2011 | 05:36 PM
February 2012 ROTM
Ahhh...Ern is THE man! +1
