F1 code fuel injector problem.
Old May 13, 2024 | 07:44 PM
  #31
GB03's Avatar
Originally Posted by GB03
Yes, on BAS itself unplugged. Yes, it will trip the kill switch if plugged in and turn upside down but I guess it's possible something internal that's messed up on it cause I tested it 4 different times to make sure when I unplugged it.
Every time OL on meter. Touch the meter prongs to each other and get a zero reading
Old May 13, 2024 | 07:47 PM
  #32
GB03's Avatar
Originally Posted by dannoxyz
Yup, you're making great progress!
That's testing on BAS itself, not harness right? No connection between those terminals means BAS is dead. Seems we're making negative progress as BAS was working earlier:
We might want to test your previous harness. It might actually be in better condition. Verify ECU connectors have correct wire-colours in correct place. If so, I'd swap it back in since we have no idea how many additional errors you'll find in this replacement one. Do same test with previous harness to compare:
1. measure resistance of grn wire terminal at BAS socket to other end chassis-ground grn wire that bolts to frame. ohms = ???
The harness that came with it was butchered. It only came with the main harness which was missing wires and pins in connectors. So definitely not gonna be better.
Old May 13, 2024 | 07:50 PM
  #33
GB03's Avatar
I measured it at the green grounds on frame, at bolt on frame, and negative post of battery.
Old May 13, 2024 | 08:21 PM
  #34
GB03's Avatar
I thought you said it was 9v before?
You skipped step?
What's colour of wires at ignition-switch connector where it plugs into harness?
Slide phone or mirror under ignition-switch and get photo.
Someone really messed up this replacement harness. Sure your previous one isn't better?
I was getting 9 volts on the pink wire before. This last time I did charge the battery overnight and got 10.7 on pink so don't know if that is relevant to why it's showing more volts or not?
Old May 13, 2024 | 08:22 PM
  #35
GB03's Avatar
I Was not hooked up to the charger when I got 10.7
Old May 13, 2024 | 08:27 PM
  #36
GB03's Avatar
​​​​​i can't get out there right now to take pic but my ignition wires are RED, PINK, RED BLACK AND BLUEISH BLACK AND ORANGE
Old May 13, 2024 | 08:33 PM
  #37
GB03's Avatar
​​​​​​The 2 ECU connectors are all in the correct place and right colors. I verified this with the diagram you sent. That's how I found the number 3 injector wire was in the wrong pin but took it out and put it in the right place .
Old May 13, 2024 | 08:34 PM
  #38
GB03's Avatar
Old May 13, 2024 | 08:41 PM
  #39
GB03's Avatar
You skipped step?
I haven't measured for volts with everything off. I can try that also. I only did the steps you sent me. I'll do that and start back where I left off which was at the fuel pump relay
Old May 13, 2024 | 09:40 PM
  #40
GB03's Avatar
I also checked voltage on the small red and white wire at engine relay and it showed .50 volts with kill switch off and .30 with it on. If that's any help or says anything. Tested with relay hooked up and without. Same voltage
