engine temp question
RE: engine temp question
227?? Describe more Is that when you are just driving down the road or in traffic or stopped? On average just riding down the road I run in the high 170s or low 180s. The hightest I've had Is a little over 220 but that was when I was stuck at a red light for a bit.
229-331 will be about as hot as she'll get under normal conditions. she's perfectly happy at those temperatures, despite what everyone says. You can have her idle in 110 degree heat all day long and she'll be just fine. The engine temperature really doesn't have much to do with the outside temperature as much as it has to do with airflow around the radiator. My bike has hit 229F idleingin the winter at 20F outside.Highway speed temperature varies. In the winter when it's around 25 or 30 degrees outside, she will hover around the 165F-170F mark on the highway. In the summer when it's 90+ degrees out, she will hover between 170F-180F.
