engine temp question
Old 07-07-2008, 11:50 AM
heskethtech87's Avatar
Default engine temp question
whats the hottest you guys have had your f4i run mine is running at 227 degrees just curius if thats normal.
Old 07-07-2008, 11:54 AM
Default RE: engine temp question
try using the search engine...what you are asking is a VERY popular question and yes that is normal
Old 07-07-2008, 11:57 AM
Mustangred's Avatar
227?? Describe more Is that when you are just driving down the road or in traffic or stopped? On average just riding down the road I run in the high 170s or low 180s. The hightest I've had Is a little over 220 but that was when I was stuck at a red light for a bit.
Old 07-07-2008, 05:16 PM
DBEAU's Avatar
Yes, sitting at a red light and hitting 227 is normal. If i'm not mistaken, you shouldn't start to worry until 240. 50mph+ on open road i'm right around 177, but if i'm stuck in traffic or sitting at red lights its anywhere from high 180's-230
Old 07-07-2008, 05:26 PM
yea sounds right.. 177 cruising nice fan kicks in at 224 when sitting at a light for a while. i think ive seen 227
Old 07-07-2008, 07:03 PM
At 254, it stops rising and starts blinking, along with a red idiot-light that blinks on the gauge.
Happened to me once...radiator fan was broken.
Old 07-07-2008, 07:09 PM
i would get up to about 227 when im out racing, i will do allot of stop and goes.
Old 07-07-2008, 07:59 PM
FLYOU's Avatar
229-331 will be about as hot as she'll get under normal conditions. she's perfectly happy at those temperatures, despite what everyone says. You can have her idle in 110 degree heat all day long and she'll be just fine. The engine temperature really doesn't have much to do with the outside temperature as much as it has to do with airflow around the radiator. My bike has hit 229F idleingin the winter at 20F outside.Highway speed temperature varies. In the winter when it's around 25 or 30 degrees outside, she will hover around the 165F-170F mark on the highway. In the summer when it's 90+ degrees out, she will hover between 170F-180F.
mutley
06-26-2014 05:47 PM
Eliteedge0788
02-28-2010 12:13 PM
gotobatter
10-08-2008 02:40 PM
NextYearCubFan
08-31-2007 03:20 AM
NotTooOldYet
03-28-2005 06:24 PM
Quick Reply: engine temp question
