Engine Swap
Old May 14, 2008 | 03:27 PM
num1polack's Avatar
Default Engine Swap
Does anyone know or has anyone here swapped a 01' f4i engine for a larger engine. I know that the 954rr seems pretty close to the same size, but not sure what will work if anything. If it is possible, what else needs to be swapped out...Thanks
Old May 14, 2008 | 03:39 PM
Todd84's Avatar
Default RE: Engine Swap
If you want a bigger motor sell the f4i and buy a 945rr. You can sell the f4i and put the money you would spend on a 954 motor and you have almost enough for a 954rr.
Old May 14, 2008 | 04:25 PM
MC_spirited's Avatar
Bigger motors mean more power.More torque twists the frame and puts additional stress on parts not designed to handle more power. Brakes may be underpowered also. If you want more power, get more bike. If you want the challange and experiance gained from shoehorning a motor, go for it. Document progress and post it up.
Mr. Bib
Nov 17, 2011 02:13 AM
bwiltrout
Jul 8, 2009 02:51 PM
hondaking69
May 27, 2009 07:39 PM
Workwell
Jan 14, 2009 10:02 PM
yellow_900_rr
Aug 16, 2006 01:11 AM
