Engine start assembly soldering break (on the handlebar)
Old Sep 2, 2011 | 10:03 PM
Decepticon42's Avatar
Default Engine start assembly soldering break (on the handlebar)
@001 Honda CBR600F4i
So I'd been head scratching as to why my headlight wiring was faulty (not the bulbs) and appeared to have no powerrunning through them. I bought an OEM new front harness as the one that was with the bike when I bought it was a mess from the previous owner attempting to install HIDs, totally failing at the task., and putting it back together incorrectly.
The new harness didn't wrk, but at least my front wiring wasn't postapocalyptic so it wasn't a loss. After looking through the wiring diagram and finding some articles on common cbr problems (a common is issue is that the soldering in the engine start assembly burns out) , I checked the engine start assembly on the right handlebar. I come to find out, that yes it is indeed there that the problem lay. One of the solders had broken off, notably the red/black solder point that completes the circuit for both lo/hi beams.
I have attempted to look for an OEM replacement on bikebandit but couldn't find it. I have no experience soldering so I don't want to try my hand at it in such a small precise spot. Does anyone know where else I could go to order an OEM start assembly, or an aftermarket one is available?
Old Sep 2, 2011 | 11:16 PM
Ok, I found somewhere else with a more complete OEM parts list. Remember if your headlights aren't working and fuses aren't the issue check your engine start button
Old Sep 3, 2011 | 01:56 AM
Ge0rgeD022's Avatar
what site did you find the part on?
MattSD
Sep 19, 2013 09:43 AM
ajohn505
Oct 20, 2008 04:55 PM
dominicanwonder5
Dec 11, 2007 09:45 AM
dominicanwonder5
Nov 25, 2007 10:35 PM
wussola
Jan 8, 2007 04:17 AM
