proper way to break in the engine?!?!?!
Old Nov 21, 2007 | 01:24 AM
dominicanwonder5's Avatar
Default proper way to break in the engine?!?!?!
what the hell is the proper way to break in the engine on this bike !?!??!!? ive been told sooooo many diff things!!! PLEASE HELP!!![:@]
Old Nov 21, 2007 | 01:53 AM
talon1000rr's Avatar
Default RE: proper way to break in the engine?!?!?!
What i done with mine wasriding all gears to 4000-5000rpm not too slow or reallyfast either up to 500km (trying not to stay on freeways for long periods) then up to 1000km was taking it up to 6000-7000rpm (couldn't wait to twist the right handle grip) then got to a 1000km and (lets see what you can do, yeah!!!)
A lot of ppl say different ways, but it bolts down to having a new tight engine that needsto wear inslowly, so you have less friction...so you don't scratch no bore with your pistons..
Hope this helps
Old Nov 21, 2007 | 10:22 AM
Onarom's Avatar
You can also check your manual that came with hte bike:
pg 212- Pay "extra attention to how you ride your bike for the first 300 miles...avoid full throttle starts and rapid acceleration" That's it. As long as you do that, you should be fine.
I would also suggest changing your oil at that 300 mile mark, but the manual only requires that the first oil change be done at 600 miles.
Old Nov 21, 2007 | 12:07 PM
blas32's Avatar
What is so hard about this...do what the manual says!!!! Who cares what others do...do what the makers of your bike say!!!
Old Nov 21, 2007 | 12:10 PM
NeverL8's Avatar
Just shift when the light comes on...[sm=smiley2.gif]
Old Nov 21, 2007 | 12:14 PM
TopGunn's Avatar
ORIGINAL: NeverL8
Warm it up good and let it rip!
Old Nov 21, 2007 | 02:33 PM
baxsom's Avatar
yeah the slow break in thing was good 20 years ago but the tolerances now are so good in engine manufacturing that all you need to do is go by the manual
a lot of people put it on a dyno and slowly run it up and down the gears for half an hour or so right off the showroom. supposedly it works real well
Old Nov 21, 2007 | 02:46 PM
s.ga.rider's Avatar
Ride it like you stole it.
Old Nov 21, 2007 | 07:18 PM
deedub's Avatar
Isn't each engine dyno tested at the factory anyway to determine if it is running properly and making up to standard HP. If that is true, who knows what RPMs they crank it up to testing it.
Dave
Old Nov 21, 2007 | 07:35 PM
sixhundredrr's Avatar
I don't discredit anyone's practice, but I trust my manufacturer to tell me good things and Honda says wait a few miles before opening her up. It can not hurt, correct?
