Draining coolant
Old Apr 17, 2006 | 02:51 PM
evilbologna's Avatar
Default Draining coolant
where abouts is the drain plug for coolant. I followed the rad hoses down to the bottom left side near the shift rod, small bolt with an arrow pointing to it. Would that happen to be it? Manual says nothing of it, and couldnt find the answer through a search, so a quick answer is all I need. Thanks. (2001 f4i).
Old Apr 17, 2006 | 03:46 PM
Tahoe SC's Avatar
Default RE: Draining coolant
forget them bolts...just pull off the hose right before the water pump.
much faster than the dribble using that bolt.
Old Apr 17, 2006 | 05:32 PM
eh you're probably right, that hose should do the trick.
waynecbr600rr
May 15, 2013 05:46 AM
flyboy1294
Feb 17, 2012 12:17 PM
SnakeTheLegend
Apr 4, 2011 06:05 PM
supersnake83
May 17, 2010 12:42 PM
madgreek
Oct 15, 2007 12:59 PM
