04 F4i FI Light wont come on
Old Oct 28, 2011 | 06:30 PM
north's Avatar
Default 04 F4i FI Light wont come on
So it was running fine this morning, this is my very first bike, but I am not new to working on motors (life spent in a cage ). However, after removing the headlight etc... to wire up the blinkers, now the FI does not turn on, nor does the light itself turn on. Any ideas?
Old Oct 28, 2011 | 06:46 PM
north's Avatar
Can't find a way to edit my post so here is the edit: It will not come on with the headlights etc... off. Is this normal? I checked and plugged the gray plug back in, but the pump still does not turn on.
Old Oct 28, 2011 | 06:50 PM
Kuroshio's Avatar
When you removed the headlight, you prolly messed the bank angle sensor up (or took it out as well). BAS kills the fuel pump if it thinks the bike is tilted too far. And the pump won't prime if the bas is missing and not properly bypassed
Old Oct 28, 2011 | 06:53 PM
north's Avatar
How can I fix this? The bike was down by the prior owner. The only thing I disconnected was the giant grey plug.
So if I am holding the headlights upside down with everything plugged in, the bike will not start? I will have to go and try it.
So how can I fix that? Is it just an issue of the headlight being upside down or unplugged?
Old Oct 28, 2011 | 07:24 PM
north's Avatar
Fixed: Apparently holding the headlights upside down DOES cause my fuel pump to not want to start. Should I look at bypassing the BAS, or should I leave it alone?
Old Oct 28, 2011 | 07:28 PM
Kuroshio's Avatar
If you're trying to fix / restore the bike and need the headlights out of the way, then yeah bypass the BAS.
Old Oct 28, 2011 | 08:04 PM
north's Avatar
Nah, I was just wiring up the blinkers. Gonna leave it broken for now since it's my first bike. What should I check out to make sure it will pass inspection?
GISNOOP
Sep 1, 2012 09:05 PM
chpsk8er630
Jun 9, 2009 09:05 PM
eric_5000846
May 28, 2009 12:56 AM
Dave71
Mar 14, 2009 08:06 AM
mysteereusone
Mar 5, 2006 06:31 PM
