03 f4i headlight problem
Old 09-19-2010, 10:05 PM
HydroPrelude85's Avatar
Default 03 f4i headlight problem
i have had this headlight problem twice recently. i crank my bike up and the headlights dont come on or flash then cut off while the bike is still running so i cut her off and on the 3rd or 4th time cranking her up the headlights come on and stay on WTF? is there anything i should check? i put in some brighter xenon bulbs about 6 months ago. any help would be nice i dont want to take it to a shop if i dont have too
Old 09-20-2010, 12:04 AM
MitchA's Avatar
Sounds like starter switch. When you crank your bike the headlights go off then back on to save juice and this switch seems to cause many of these issues. I cleaned mine up and hvent had the issue in the last month or so, though I havent owned the bike very long.
Old 10-13-2010, 09:15 PM
it has to be the starter switch because the last time i cranked the bike and the headlights didn't come on i just flicked the start button and the headlights turned on and stayed on
Old 10-14-2010, 07:33 PM
bigboi18184's Avatar
you can take the housint apart and the solder is probably either cracked or getting ready to come off. Just hit it with a soldergun to heat get it back working right. Had this problem with my F4i last year and bought a new switch....coulda just saved the $$
Old 12-09-2010, 03:53 PM
i checked the headlight relay and it seemed fine now i will take the housing off the right handle bar and check it out if that checks out i wont know what else to try but it could have been that the aftermarket bulbs i put it were not the right watts or it could be that i used to always run my high beams 24/7 i put the stock bulbs back in and don't run the high beams anymore but i haven't been riding much since its in the 30's to 40's here in NC plus i have been taking the truck hunting in the morning and afternoon
cajun rider
03-22-2012 07:37 PM
rnora1
06-11-2009 10:28 PM
bottlebaby
06-04-2009 09:38 PM
josemiguel
10-20-2007 09:06 PM
Quick Reply: 03 f4i headlight problem
