Headlight Problem
Old Oct 20, 2007 | 06:28 PM
josemiguel's Avatar
Default Headlight Problem
I just bout a 93 cbr f2 but the healdlight doest turn on at all. i checked the fuse and i went as far as changing the wiring harness.
Old Oct 20, 2007 | 07:46 PM
SpiritRR's Avatar
Default RE: Headlight Problem
Assuming you changed the bulb, too, I would check the contacts of the light itself, where the plug from the harness attaches, and see if it's corroded or loose. Maybe check ebay for a new light altogether: click me.
Old Oct 20, 2007 | 09:06 PM
TripsD's Avatar
I had the same problem a couple months ago. It ended up being the electronics in the run/stop switch on the handle. The power runs from the battery to the left clip-on (hi/lo beams) then to the right clip-on (run/stop) then to the head light. Check all the wiring going from the left to right clip-ons and then from the right clip-on to the head light. Hope that might help.
cbr6rider
Jun 26, 2019 08:00 PM
cajun rider
Mar 22, 2012 07:37 PM
rnora1
Jun 11, 2009 10:28 PM
bottlebaby
Jun 4, 2009 09:38 PM
